Activity › Forums › Adobe After Effects › roto brush freeze or preview not working ?
  • roto brush freeze or preview not working ?
    Posted by Alfred Durand on February 20, 2011 at 6:14 pm
    Hi everybody,
    First post here !
    Ok to make it simple the roto brush is working only if I jump frame to frame (command+left or right key). If I render using preview or freeze the mask starts well then progressively goes completely bezerk !
    I’ve got the latest version (10.0.1)
    Do I miss something ?
    Alfred
    Alfred Durand replied 15 years, 7 months ago 3 Members · 5 Replies
  • Tudor “ted” jelescu
    February 20, 2011 at 8:21 pm
    Roto Brush is not an easy tool- it takes some reading to figure it out.
    Here’s a tutorial that can help.
    And this one.
    And of course this linkfrom adobe help… you know, sometimes it’s really easy if you just google it yourself and do some reading.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Todd Kopriva
    February 20, 2011 at 9:32 pm
    Echoing Tudor:
    Watch the tutorials linked to from this page and see if they help you to figure it out:
    https://blogs.adobe.com/toddkopriva/2010/04/roto-brush-in-after-effects -cs.html
    Pay special attention to the details in those tutorials and in the Help document about Roto Brush spans and how they grow when you make corrective strokes.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Alfred Durand
    February 20, 2011 at 10:25 pm
    Thanks for your answer.
    I’ve looked at tutorials before using roto brush. Maybe my explanations was not clear. English is not my first language. I can achieve a perfect mask. But when I use the freeze button it doesn’t work anymore. The programmation I’ve done is gone. And If I use the ram preview button it also goes wrong. But If I move frame by frame I get my preview right.
  • Alfred Durand
    February 21, 2011 at 12:03 am
    For now the only workaround I found is rendering my comp with alpha and then re-use it in my principal composition. Like I said it’s just the freeze and ram preview button that don’t work. Rendering (or previewing frame by frame) works.
  • Alfred Durand
    February 21, 2011 at 5:26 pm
    I’ve reinstalled after effects and now it works !
    Thanks for your help.
    Alfred.
