rotation wobbly
I’ve imported an illustrator file that has a bevel and extrude effect on it into ae. When I make this layer 3-d and move the anchor point to the center and rotate with the z axis the objet turn with an exaggerated wobble. Is this because ae has trouble with illustrator’s extrude and bevel, or could it be because my drawing isn’t perfect. Any way to work around this?
Thank you!
h
