Activity › Forums › Adobe After Effects Expressions › rotation with wiggle
  • rotation with wiggle
    Posted by Gon Perdigao on September 13, 2010 at 10:47 am
    hi there i want to wiggle the rotation in one axis, and i wanted that the roation have a range betwen -10 and 10, i have this expression for the wiggle in one axis :
    w = wiggle(5,effect(“Slider Control”)(“Slider”));
    v = value;
    [v[0],v[1],w[2]]
    but how i add the variation between 10 and -10 ?
    Thanks a lot!
    Dan Ebberts replied 16 years ago 2 Members · 5 Replies
  • Dan Ebberts
    September 13, 2010 at 3:15 pm
    Like this?
    w = wiggle(5,10);
    v = value;
    [v[0],v[1],w[2]]
    Dan
  • Gon Perdigao
    September 13, 2010 at 3:55 pm
    hi Dan,
    Sorry i meant 10 degrees, in that case i ned to create variable to say that the value is 10º and minus 10º, right?
    But i don’t know how to do it
    Thanks a lot
  • Dan Ebberts
    September 13, 2010 at 4:11 pm
    Sorry, I guess I don’t get what you’re trying to do. The amplitude parameter is already in the units of the property hosting the expression. For a rotation expression, that’s degrees. So this rotation expression:
    wiggle(5,10)
    should wiggle in the range of -10 degrees to +10 degrees centered around the pre-expression value. Is that not what you want?
    Dan
  • Gon Perdigao
    September 13, 2010 at 4:26 pm
    yes is that what i want.
    Is there a way to to enable a slider control?
    thanks a lot
  • Dan Ebberts
    September 13, 2010 at 4:42 pm
    Your first example had a slider in it, but clearly that wasn’t doing what you want. What do you want the slider to control? Maybe an example with numbers would help.
    Dan
