Activity › Forums › Adobe After Effects Expressions › Rotation with duration, holds for 1 sec. then repeats
Posted by John Osteen on November 2, 2011 at 11:45 pmI’m trying to set up an expression that will rotate a null 36 degrees every second, but I need the rotation to last 5 frames and hold its position until the next second comes around. Does anyone have any ideas on this one? I’m at a complete loss.
John Osteen
DastardlyStudios.comRoman Stupak replied 6 years, 9 months ago 6 Members · 16 Replies -
Dan Ebberts
November 3, 2011 at 12:10 amThis should be close:
segDur = 1;
rampDur = 5*thisComp.frameDuration;
degrees = 36;
t = (time – inPoint)%segDur;
seg = Math.floor(time/segDur);
degrees*seg + linear(t,0,rampDur,0,degrees)Dan
John Osteen
November 3, 2011 at 12:23 amDan, you are the man! Would’ve never figured that out on my own. Thank you.
One last question though, what would I change if I need another one to rotate every 10 seconds?
John Osteen
DastardlyStudios.com -
Roland R. kahlenberg
November 7, 2011 at 6:29 pmHi Dan, the Expression script doesn’t seem to like layers not starting at time=0. Is there a way to fix this elegantly?
Cheers
RoRKIntensive AE & Mocha Training in Singapore and Malaysia
Adobe ACE/ACI (version 7) & Imagineer Systems Inc Approved Mocha Trainer -
Dan Ebberts
November 7, 2011 at 7:52 pmGood catch. This should fix it:
segDur = 1;
degrees = 36;
seg = Math.floor((time-inPoint)/segDur);
November 8, 2011 at 9:42 pmThanks Dan!
RoRK
John Madison
April 16, 2012 at 3:56 pmHi Dan,
I was looking for a similar expression, however my set is slightly different. I was wondering if you can help!
I have the following set up with stroke-only circles and masks:
The black bit is just another circle.
I want to rotate the black circle every 5 frames but not a transitional rotation rather every 5 frames it rotates to its new position (increments of 40 degrees, i.e. overlapping the blue circles) holds for 5 frames and repeats.
How do i got about achieving this?
Dan Ebberts
April 16, 2012 at 4:05 pmThis should work:
f = timeToFrames(time-inPoint);
value + Math.floor(f/5)*40Dan
George Judd
October 23, 2018 at 5:58 pmHey Dan,
I am trying to achieve a similar effect. However, I need my null to rotate 1 degree every 3 frames and that is all.
I have been trying to tweak your expression, but my limited understanding of expression hasn’t got me very far!
If you had any recommendations on books or videos that would help me get a better grasp on expression I’d really appreciate it!
Many thanks!
George
Dan Ebberts
October 23, 2018 at 7:55 pmTry this:
value + Math.floor(f/3)Dan
