Activity Forums Maxon Cinema 4D Rotation tool text color
  • Rotation tool text color
    Posted by Jack Cook on January 26, 2006 at 4:58 pm
    In 9.5, the rotation tool has these colored bands to help you rotate, and also has a text readout of the rotation in degrees. This is great, but the problem is the text is white, and is almost always on top of the band I’m using to rotate, which turns yellow, making the text hard to read. Is there a way to change the color of the text readout for the rotation tool? I’ve looked all over the preferences and the HUD configuration window and I can’t find anything. Or in the manual either.
    thanks,
    Jack
    Jack Cook replied 20 years, 7 months ago 2 Members · 2 Replies
  • Brian Jones
    January 26, 2006 at 10:53 pm
    looks like it would be difficult to figure out which is the right one for the text (and it probably would change some other text too) – unless someone knows which it should be, but!
    the color of the selected axis is simple – Preferences/Viewport/Colors/Selected Axis – you could make it darker so the text shows better
  • Jack Cook
    January 27, 2006 at 1:55 pm
    Thanks, Brian, that did it. I made the Selected Axis color a dark gold, and the readout shows up fine.
    Jack
