Activity Forums Maxon Cinema 4D Rotation TOOL center: arbitrary placement?
  • Rotation TOOL center: arbitrary placement?
    Posted by Eric Chard on January 8, 2017 at 11:51 pm
    I’m sure this is a perennial favorite…
    I’d like to set the rotational center of the Rotation TOOL to be away from my selection: that is, I’ll be rotating my selection along an arc.
    How does one do that? Currently, the rotational center is at the center of the selected items.
    “Putting the HARM in ‘harmonica’ since 2005.”
    Jim Scott replied 9 years, 7 months ago 2 Members · 1 Reply
  • Jim Scott
    January 9, 2017 at 2:16 am
    Create your object – a cube for example.
    Make it editable – (C)
    Enable axis modification – (L)
    Move the axis with the move tool – (E)
    Disable axis modification – (L)
    Use Rotate tool, or adjust H,P,B in cube’s coordinates, to rotate it around re-centered axis.
