Activity Forums Maxon Cinema 4D Rotation snapping
  • Rotation snapping
    Posted by Martyn Morris on May 15, 2009 at 3:16 pm
    Hi there I’m having modeling problems.
    I have an editable cube and when I select point, polygon or edge with the rotation tool it drastically snaps the object in to an undesired shape.
    Is this the new snap to Y grid or is the computer I’m using having a bad day.
    How do I get to the snap to Y grid dialog box to turn it off.
    Please could some one help as I’m tearing my hair out here.
    Thanks, Martyn.
    Adam Trachtenberg replied 17 years, 4 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    May 16, 2009 at 5:54 pm
    You might have snapping turned on, but even if you do, just selecting a point/edge/poly shouldn’t cause it to snap. You can access the snap settings by hitting the p key, or by clicking on the rotate tool and looking in the tool properties (snap settings tab).
