Activity Forums Adobe After Effects Rotation of composition with a repeater inside (déformation)
  • Rotation of composition with a repeater inside (déformation)
    Posted by Max Arch on December 5, 2015 at 4:40 pm
    Here the problem,
    when i rotate there a deformation that happen. I want that it stay as square.
    First, I have try to rotate only the reapeater.
    Next, I have create a new composition(square). Thinking no deformation will happen, since it not the repeater I rotate but my composition inside a other composition.
    From what i know it suppose to work but…. I don’t know where the problem happen and how to correct it.
    hope i am clear.
    Max Arch replied 10 years, 9 months ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    December 6, 2015 at 7:45 am
    Either the containing composition is not scaled proportionally, in which case the easiest solution is to scale it proportionally, OR you have a non-square pixel aspect ratio, and need to turn on pixel aspect ratio preview (click the icon with rectangle and horizontal double arrow below the viewer).
  • Max Arch
    December 6, 2015 at 2:50 pm
    thanks
    i will check that
