Activity › Forums › Maxon Cinema 4D › Rotation Issue
  • Brian Jones
    May 6, 2011 at 2:41 pm
    it’s hard to tell from the picture. It looks like the axis is in approximately the right place so it’s hard to tell what might be the problem. Have you centered the axis with Structure/Axis Center? Otherwise I’d probably have to see the scene file.
  • Ciprian Darius
    May 6, 2011 at 3:03 pm
    YES that was the solution. Told you I was a bit bad at this XD. Thank you <3
