Activity Forums Adobe After Effects Expressions Rotation expression won’t animate
  • Rotation expression won’t animate
    Posted by Anja Riehl on January 17, 2017 at 11:34 am
    Hello there,
    I have a problem. I have two compositions. The main composition and a sub composition.
    In each of the composition there is a 3d camera with a cam ctrl layer. I have connected the cam control layer of the sub composition to the cam ctrl layer of the main composition.
    So, I control the camera with the cam ctrl layer in the main composition.
    Everything works fine so far. But when I try to animate the cam ctrl layer in the main composition and I set keys, it won´t work. No animation.
    Can somebody help me out?
    Thank you so much in advance.
    Anja
    This is the expression that I am using on the cam ctrl layer in the sub composition:
    comp("SCENES 1-10").layer("CAM ctrl").transform.xRotation
    comp("SCENES 1-10").layer("CAM ctrl").transform.yRotation
    comp("SCENES 1-10").layer("CAM ctrl").transform.zRotation
    Anja Riehl replied 9 years, 7 months ago 2 Members · 2 Replies
  • Emre Anil
    January 17, 2017 at 2:40 pm
    Did you connect all the rotations separately?
    This is working for me:
  • Anja Riehl
    January 17, 2017 at 2:56 pm
    Thanks so much for your help, I already fixed it….yippiihhh 😀
