Activity Forums Adobe After Effects Expressions Rotation Expression needed.
  • Steve Roberts
    August 3, 2006 at 4:07 pm
    Just use keyframes. Set the first keyframes to the number of times that the layer is rotated, then set the second keyframe to zero. Right-click (ctrl-click on mac) on the second keyframe and select “ease in”.
    If you want to fine-tune that, look in the help to see how to adjust value graphs, probably under “fine-tuning animation”.
  • Tcelos
    August 3, 2006 at 4:22 pm
    I tried that, and it doesnt look organic enough. I will keep playing with it and still search for any expressions.
    Thanks.
    los
  • Mike Clasby
    August 3, 2006 at 4:44 pm
    This oldie but goodie from Dan.
    exponential curve between two key frames, so set two keyframes.
    Date: Nov 16, 2004 at 12:58:36 pm
    Subject: Re: Expression for exponential scale
    This should give you an exponential curve between two key frames:
    if (numKeys > 1){
    v1 = key(1).value;
    v2 = key(2).value;
    t1 = key(1).time;
    t2 = key(2).time;
    if (time > t1 && time < t2){ t = time - t1; T = t2 - t1; k = Math.log(v2/v1)/T; v1*Math.exp(k*t) }else{ value } }else{ value } Dan ----------------------------- yikes, again Note for rotation this expression doesn't like "0", you get the old "After Effects Warning: Invalid numeric result (divide by zero)." So insead of zero, use "0 rotations, .01 degrees" or start at 1 rotation and go to 5 rotations, etc.
