Activity Forums Adobe After Effects Expressions Rotation expression
  • Rotation expression
    Posted by Kim Petersen on December 12, 2007 at 12:22 pm
    Hi again,
    I want to be able to control the rotation of several objects (to be part of a transition). I dug up this expression here at the Cow and I tried to convert to rotation, but without any luck. I’m sure you will be able to what’s wrong in an instant 🙂
    I need the layer to rotate in a maximum of 180 degrees.
    Thanks guys.
    Best,
    Kim
    mouse_layer = thisComp.layer(“mouse layer”);
    beginRotation = 0;
    endRotation = 180;
    beginDistance = 200;
    endDistance = 0;
    dis = length(this.position, mouse_layer.position);
    val = ease(dis, beginDistance, endDistance, endRotation, beginRotation);
    [val, val]
    Trent Armstrong replied 18 years, 8 months ago 5 Members · 7 Replies
  • 7 Replies
  • Filip Vandueren
    December 12, 2007 at 2:03 pm
    Just drop the last line: [val,val] is not necessary.
    It would make it a 2-dimensional value like a position or scale.
    But rotation is just a number.
  • Jamie Bradshaw
    December 12, 2007 at 2:07 pm
    Hi Kim.
    Are you using this expression on a rotation property? If so, you need to make sure it returns just one value, as opposed to two.
    So replace:
    [val,val]
    … with just:
    val
    Jamie
  • Kim Petersen
    December 12, 2007 at 2:23 pm
    Hi!
    Yes, I need it on a rotation property. More specific on the Y-axis.
    [Val] would suffice?
    Thanks again!
    /Kim
  • Mike Clasby
    December 12, 2007 at 6:16 pm
    So, Methinks you’re talking a 3D layer?
    If so, put the expression on the Y Rotation stopwatch.
    Like they suggested, just change the last line to:
    val
  • Mike Clasby
    val
  • Mike Clasby
    December 12, 2007 at 6:20 pm
    Delete me. I’m caught in account renaming limbo.
  • Trent Armstrong
    December 13, 2007 at 7:05 pm
    Hi!
    Depending on how complicated it needs to be, you might just need to use the pickwhip to link the Y Rotation of all successive layers to the first layer that rotates.
    Trent
    Trent Armstrong – Creative Cow Leader
    https://www.dallasaeug.com
