Activity Forums Adobe After Effects Expressions Rotation and trigger expression rig
  • Rotation and trigger expression rig
    Posted by Jonathan Reyes on January 16, 2026 at 10:51 am
    Hi, I’ve uploaded a project to help. I’m trying to build a rig. Basically I have 24 pre-comped layers in a circular pattern parented to a null so I can rotate as a whole. They need to stay up right. I have that expression part done.
    As the layer enters the tigger box (range) I need that one layer in the box to scale up slightly to 75 and move in the positive x position slightly. Adjustable by slider in a controller null. I have the scale expression working. Id also like to trigger a prebuilt animation within the preComp.
    My issue currently is the position translation in the x axis. The expression works sort of until I rotate 180 degrees these layers move in the opposite direction and in the Y axis which I don’t want.
    I have not started on how I would go about triggering the prebuilt animation in the pre-comp.
    any tips would be much appreciated.
    Scale expression:
    trigger = thisComp.layer(“TRIGGER”);
    p1 = toComp(anchorPoint);
    p2 = trigger.toComp(trigger.anchorPoint);
    d = length(p1, p2);
    r = trigger.effect(“Range”)(“Slider”);
    maxS = trigger.effect(“Max Scale”)(“Slider”);
    minS = 50;
    s = ease(d, 0, r, maxS, minS);
    if (d > r) s = minS;
    [s, s]
    Position expression:
    d = length(p1, p2);
    maxO = trigger.effect(“Max Offset”)(“Slider”);
    o = ease(d, 0, r, maxO, 0);
    if (d > r) o = 0;
    [value[0] + o, value[1]]
    Andy Diesel replied 6 months, 3 weeks ago 2 Members · 1 Reply
  • Andy Diesel
    January 27, 2026 at 10:22 am
    Hi, Jonathon
    I greatly appreciate your generosity and sharing with me the work that you’re doing as well.
    Before I enter into it I jsut wanted to share my thanks.
    Have a great 2026
