Activity Forums Adobe After Effects Expressions Rotating the Shortest Way Possible
  • Rotating the Shortest Way Possible
    Posted by Frankie Jones on December 8, 2022 at 3:14 pm
    How can you ease between 2 values the shortest way possible i.e. ObjA is at 2 degrees and ObjB is at 350degrees, how do you make ObjA rotate 2,10,359,358… etc. rather than 2,3,4,5,6…. The code below weights between 2 values: Value A when Slider is 0, Value B when Slider is 1. Something I can’t figure needs to be added to make it Rotate forwards or backwards depending on which is shortest way:
    // On Rotation
    var total = 0, totalWeight = 0, remWeight = 0;
    var rot = thisComp.layer("Target").transform.rotation);
    if (hasParent) rot = parent.rotation;
    var fade = effect("Slider Control")("Slider"); // Slider is 0 to 1
    total += fade*rot; totalWeight += fade;
    remWeight = 1 - totalWeight;
    totalWeight==0 ? value : linear(remWeight,total/totalWeight,value);</li-code>
    Filip Vandueren replied 3 years, 9 months ago 2 Members · 2 Replies
  • Filip Vandueren
    December 8, 2022 at 9:21 pm
    The easiest fix is to use Orientation on a 3D layer.
  • Filip Vandueren
    December 9, 2022 at 8:58 am
    I couldn’t really deduce what you were doing with the weight variables.
    Here’s an example that bases itself off of the rotation keyframes already present and always takes the shortest route (always <=180°)
    nk = nearestKey(time);
    prevKey = key ( nk.time >time ? nk.index-1||1 : nk.index );
    nextKey = key( Math.min(numKeys, prevKey.index + 1) );
    delta = (nextKey.value - prevKey.value)%360;
    shortRoute = Math.abs(delta)>180 ? (Math.abs(delta)-360)*Math.sign(delta) : delta;
    // longRoute = Math.abs(delta)<180 ? (Math.abs(delta)-360)*Math.sign(delta) : delta;
    linear(time, prevKey.time, nextKey.time, prevKey.value, prevKey.value + shortRoute);
