Activity Forums Adobe After Effects rotating text
  • rotating text
    Posted by Criis Daw on August 3, 2006 at 12:42 pm
    Hi can anyone help please ???
    I have my text going round in a cylinder like a news show type of thing.. It looks reallt nice.. i was wonering if anybody know a way to make the reverse side not light up so much or to give it some depth . I ussed cc cylinder to make the tect cylinderr.
    Any help much appreciated
    cheers
    Criis Daw replied 20 years, 1 month ago 2 Members · 3 Replies
  • Steve Roberts
    August 3, 2006 at 1:00 pm
    I’d normally suggest Zaxwerks Invigorator for Depth, but I don’t know if there’s an easy way to orient the letters in a circle using that app. Hm.
    To only render the outside, look at the settings for the CC Cylinder effect. If you want the inside and outside to be different, dupe the layer and set one to “outside” and the other to “inside”, then reduce the opacity of the “inside” layer, or reduce its brightness.
  • Criis Daw
    August 3, 2006 at 1:31 pm
    dont know where i’d be without you…
    thanks a million
  • Criis Daw
    August 5, 2006 at 2:49 pm
    ha ha…
    very cool trick
    thanks
