Activity Forums Adobe Premiere Pro Rotating phone footage
  • Rotating phone footage
    Posted by Peter Northall on October 22, 2020 at 9:19 am
    Hi, when I rotate (by 270 deg) phone footage using effects panel the image rotates within the image frame, but the frame remains vertical. I haven’t come across this before. Can anyone tell me why this is happening and how to correct it please?
    Larry Chapman replied 5 years, 11 months ago 2 Members · 1 Reply
  • Larry Chapman
    October 22, 2020 at 12:19 pm
    That’s how it always works. Rotate in the effects panel rotates that single item. You can create a new sequence with a new aspect ratio but there is no way to change the aspect ratio of a sequence with an effect.
