Activity Forums Adobe After Effects Rotating-panels Wall
  • Rotating-panels Wall
    Posted by Alfonso Gamez jordano on July 8, 2008 at 4:53 pm
    Hi.
    First, check out this draft of what I’m trying to create: (6,5 MB)
    https://www.megaupload.com/es/?d=T1WR61I8
    I want to create a title scene that consists on a “wall” divided in 6×6 rectangles or panels, that, by rotating, uncover the words.
    In After Effects I created a Grid, and then, by using rectangular masks that coincide more or less with the grid lines, I simulated the grid being really made of panels.
    The problem is that, as you can appreciate in the video, there are some artifatcs, such as a small white line at the left of the first title, or, when rotating, the coincidence of both rotating and non rotating layers, in the anchor point.
    And also, I believe the effect looks too much 2.5D rather than 3D… The panels are completely flat you see.
    So, I wanted to know your ideas for making this look more realistic, preferably doing things in a completely different way. I know how to use some Blender, or maybe there are better ways to do the same inside AfterFx.
    I would be very grateful for any answer on the topic, even if you don’t solve my problem…
    Anyway, regards,
    Alfonso
    Chris Wright replied 18 years, 1 month ago 2 Members · 3 Replies
  • Chris Wright
    July 8, 2008 at 10:24 pm
    there’s many ways to extrude but off the top of my head, you could try trapcode with primitive 3-D shape rectangle then add video to it.
    and I would strongly suggest using a 3-D light to give it depth.
  • Alfonso Gamez jordano
    July 8, 2008 at 11:35 pm
    Thanks for the tip, Chris, but I haven’t got that plugin… 🙁
    See if you can remember other technique
    Thanks =)
  • Chris Wright
    July 9, 2008 at 8:51 pm
    1. Adobe Illustrator extrude rectangle, then import into AE
    2. Cinema 4d extrude
    3. Maya extrude
    4. no plugins or software, use a Null object, set 6 solids to rect. shape, then parent Null to layer transform with pick whip.
