Activity Forums Zaxwerks rotating letter problem
  • rotating letter problem
    Posted by Brandon on November 11, 2005 at 8:38 am
    I am trying to rotate a letter but when I rotate it, I need it to be the same on both sides, how do I do this? It’s flat on one side and has 2 stacks on the other side. Thanks
    Serge Hamad replied 20 years, 10 months ago 2 Members · 1 Reply
  • Serge Hamad
    November 11, 2005 at 6:16 pm
    Hi Brandon,
    I guess you applied an object style then a regullar Outside Edge. In this case you need to go to the Set-Up window, click on the Material Set-Up and in the Palette menu you click on Clear all splits.
    Let us know if you still have problems.
    Salut.
    Serge
