Activity › Forums › Adobe After Effects › Rotating labels…
  • Rotating labels…
    Posted by Albert Fung on May 11, 2011 at 6:37 pm
    Dear all,
    I am currently working on a medical animation, and in a certain scene I have a 3D render of a liver, with a certain section labeled with text and a label line in After Effects.
    The liver then rotates to a different view, and I’m hoping to have the label and label line follow the labelled section. The label text itself can be tweaked using the motion path, but I can’t seem to figure out a good way to have the label line follow both the text, and the section it’s supposed to point at.
    I was wondering if anyone could give me an idea on how to approach this, or would it just be easier if I went into my 3D software package, create a thin cylinder that acts as a line, and render it with the liver.
    Thanks in advance for your help.
    Albert
    Kevin Camp replied 15 years, 4 months ago 2 Members · 1 Reply
  • Kevin Camp
    May 12, 2011 at 2:53 am
    if you wanted to do this in ae, you’d want to orbit the camera around the liver in the 3d program (vs. rotating the liver), then import the camera data into ae. that way the camera move will match the liver animation and any 3d layers you add in ae will match that move.
    i don’t know what 3d software you used, but i used to do this in cinema 4d many years ago (c4d 7 and ae5.5 i think) it was pretty new then, but i think it’s a more common process now, so many 3d programs can probably export that data to ae.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
