Activity › Forums › Apple Final Cut Pro Legacy › ROTATING Image in FCP – Image gets distroted or pixilated as the image rotate – Please Help
  • ROTATING Image in FCP – Image gets distroted or pixilated as the image rotate – Please Help
    Posted by Tarsue on August 15, 2005 at 10:29 pm
    I have one problem that is not going away in fianl cut pro.
    I’m trying to use FCP to rotate an image (Photoshop Image/picture)
    When I rotate it by manipulating the Motion Tab in the Viewer
    And play it — It roatates the picture all-right (It does what I want)
    But the picture gets pixilated – or distorted – or fuzzy .
    It looks like the image pixles are moving- roatting – so the end result
    is that the rotated image does not look good
    This is a high quality 300 DPI image of a painting.
    This is killing me –
    I have been looking at the Forums .. maybe I’m not looking at the right place .. can anyone suggest anything
    Can anyone offer a solution PLEASE!! HELP!!!!
    Rick Dolishny replied 21 years, 1 month ago 4 Members · 4 Replies
  • Arnie Schlissel
    August 16, 2005 at 12:36 am
    First, are you monitoring your work on an external monitor? If not, then you’ve no proper way to judge the real quality of your work.
    Second, have you rendered the still at full quality? If not, then you’re not seeing the real quality of what your doing.
    Third, there are no inches in video, DPI is meaningless. What are the real dimensions, in pixels, of your picture? Is it at least large enough to do the move that you’re describing? From the sound of it, your dimensions should be at least 1440X960 pixels, maybe as high as 2160X1440.
    Arnie
    https://www.arniepix.com
  • Tarsue
    August 16, 2005 at 2:10 am
    Thanks for responding
    It has nothing to do with the dimension. The dimensions are large enough,
    The picture is rendered in FCP.
    Your suggestion to make this a larger file did not work.
    I still have the same issue,
  • Michael Peele
    August 16, 2005 at 3:08 am
    If your pixels are buzzing try a small blur – 1 to 2 pixels.
    Or try reducing the resolution – I know it sounds strange but, if you only need the picture to fill the screen, you only need 720×480 or thereabouts. If the picture is at some point more than full screen, give yourself a little more resolution to work with.
    Is your image broadcast safe – do you have bright reds or full whites? You may want to apply the broadcast safe filter or mess with the colors in photoshop.
    Hope one of these solutions works,
    Mike Peele
  • Rick Dolishny
    August 16, 2005 at 10:09 am
    Just turn on the motion blur tab and drag the slider down to under 100 units. 4 samples (default) is OK most of the time.
    And definitely preview on the NTSC once it’s done. 🙂
    – R
