Activity Forums Adobe After Effects Rotating Expressions
  • Rotating Expressions
    Posted by Julio Crespo on August 13, 2006 at 2:38 pm
    I want to rotate four objects around a circualr path and on it axe a time. i try parenting and pick whip but the objects leave the circualar “orbit”. any budy know a expression to do that???…..DAN EBBERT help me
    Mylenium replied 20 years, 1 month ago 3 Members · 5 Replies
  • Mike Clasby
    August 13, 2006 at 5:10 pm
    Did you parent the objects to a Null layer and then rotate the null?
  • Julio Crespo
    August 13, 2006 at 6:38 pm
    Yes, but not working. only one objects fallow the “orbit” but when Parenting other layer not workin
  • Mike Clasby
    August 13, 2006 at 8:28 pm
    You need do parent each object individually to the null. That should work.
  • Julio Crespo
    August 14, 2006 at 5:05 am
    No.. I do that and not work
  • Mylenium
    August 14, 2006 at 5:48 am
    You must be doing something wrong. Make sure you parent all your layers at their initial pose frame (frame 0). Check if all your child layers are parented properly to your Null object on the dropdown list readout.
    Mylenium
    [Pour Myl
