Activity Forums Adobe After Effects Rotating circle shape on the spot in After Effects
  • Kalleheikki Kannisto
    November 13, 2015 at 1:29 pm
    From the looks of it, your circle is not in the center of the square, so if they have a common center point, it is off-center. If you select the circle layer, you should see the anchor point, which is the point the layer rotates around. You can move it with the “pan behind” tool.
    Alternately, you can draw a new shape layer for the dotted line from the center point holding ctrl+shift (for drawing from center and constraining proportions). A shape layer Stroke has Dashes option.
  • Santiago Pilgrim
    November 13, 2015 at 1:38 pm
    Thank you for kindly pointing out the obvious error, I traced it back to when I separated the layers in Photoshop, the circles were not centered… Doh! Thanks 🙂
