Activity › Forums › Adobe After Effects › Rotating around Footage ?
  • Jimmy Brunger
    January 18, 2010 at 10:03 am
    You can rotate the video clip as if it were a 2D ‘card’ or flat plain, but if you wanted some realistic rotation you would need to roto and separate some of the different elements in the shot, then move them forward/backwards in Z-space, so that the parallax is correct. You would no doubt then need to paint in some of the background to fill the holes left around you foreground objects. Not a quick job, but quite achievable if it’s only a small camera rotation.
    Your best bet is to have a play with MochaAE for tracking/roto of your footage and then look in the podcasts/tutorials here on the Cow for ways to create the depth. Andrew Kramer did something with an Egyptian still landscape, although it’s the same basic principle. Also, there is a stereoscopic workflow video from someone who extracted depth from Nosferatu on the Imagineer website that might be useful to you.
    Be patient!
  • Christopher Rotter
    January 18, 2010 at 2:02 pm
    How small of rotations could I do ? What about 60 degree ?
  • Jimmy Brunger
    January 18, 2010 at 3:32 pm
    Why don’t you try it? Cut out elements of one frame of it that best represents the shot – pull out the depth that matches the shot, then rotate. See how it looks!
    January 19, 2010 at 12:17 am
    I suppose, you are right. Thank you 🙂
