Activity › Forums › Adobe After Effects › Rotating around an anchor but keeping object upright
  • Rotating around an anchor but keeping object upright
    Posted by John Shand on July 18, 2012 at 11:04 am
    Hi all,
    I have a set of shapes that i want to move around the screen but maintain its upright position when it is rotating.
    At the moment I have put the anchor point in the centre of the comp but when I rotate the object, the shape turns with it. There is text within the shape that is why I want to maintain its upright position so it is easy to read.
    I hope this makes sense to anyone.
    I found this example which might help you understand what I’m trying to achieve.
    https://www.hypertransport.org/images/productsMain2.jpg
    Manuel Madariaga replied 10 years, 10 months ago 4 Members · 8 Replies
  • 8 Replies
  • John Cuevas
    July 18, 2012 at 11:45 am
    Assuming you arranged your shapes in the comp and parented them to a null object in the center of the screen. Open up the rotation property of of one your objects and “alt + click” to open the expression editor. Type in “-(” then pick whip to the null’s rotation property. Finally close the expression with another “)”. You should get this:
    -(thisComp.layer("Null 1").transform.rotation)
    Simply you are telling your objects to rotate the exact opposite way the parent is rotating.
    Here it is in action: 4411_rotationexpression.aep.zip
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • John Shand
    July 18, 2012 at 12:08 pm
    John,
    Thank you so much for your time.
    The effect you made is exactly what I want.
    I applied the same expression to my image but my result was that it was rotating in an opposite direction but was not keeping upright like your text.
    Did I miss something?
    Thanks again.
  • John Cuevas
    July 18, 2012 at 12:55 pm
    You need to explain your setup a bit more, when you say you applied the expression to an “image”, are you just working with one layer? The method I used works when you have multiple objects parented to a single controller in the middle of the comp.
    If you have one layer, you would need to break the layer into individual components, parent them to a control in the middle of the composition(null) and then apply the expression.
    Thinkck.com
  • John Cuevas
    December 6, 2012 at 12:30 pm
    Did that answer your question
    Thinkck.com
  • John Shand
    December 6, 2012 at 1:23 pm
    Hi John,
    Sorry for the late response I just completely forgot. Yes that worked perfect. Thanks for your help and time.
  • John Cuevas
    December 15, 2012 at 1:44 pm
    Then I’m glad I was able to help.
    Thinkck.com
  • Lyubo Yanev
    August 6, 2015 at 7:49 am
    Thanks! Exactly what I was searching for too!!
  • Manuel Madariaga
    November 17, 2015 at 9:22 pm
    Thaks John, you just saved me a lot of time 😉
