Activity Forums Maxon Cinema 4D Rotating Animated Objects in Cinema4D
  • Rotating Animated Objects in Cinema4D
    Posted by Gareth Wood on July 28, 2010 at 1:28 pm
    Hi, I have a Cinema4D 11 question.
    I’ve used keyframes to animate a ball that bounces along a street. I’d like to make copies of it in order to have lots of balls going in different directions. Is there any way of flattening the animation so i can rotate not only the object but also the animation path?
    Many thanks
    Gareth Wood replied 16 years, 1 month ago 3 Members · 4 Replies
  • Adam Trachtenberg
    July 28, 2010 at 2:47 pm
    You can bake the animation using the Timeline>Function>Bake Objects command, but that will create a key on every frame which uses a lot of RAM.
    Instead, you might want to use Tools>Animation mode. That allows you to move and rotate animated objects *and* their animation paths at the same time.
  • Cactus Dan
    July 28, 2010 at 2:48 pm
    Howdy,
    You could put the ball under a parent Null object, and rotate the Heading of the Null object. This would give you a different direction.
    Remember that all animation keys are in local coordinate space, so the ball’s animation would be local to it’s parent Null in the above scenario.
    Adios,
    Cactus Dan
    Cinema 4D R10 XL Bundle, BodyPaint, Dynamics
    http://www.cactus3d.com
    http://www.cactus3d.com/Plugins.html
  • Cactus Dan
    July 28, 2010 at 2:53 pm
    Howdy,
    Oh, cool. I didn’t know about that one.
    Adios,
    Cactus Dan
  • Gareth Wood
    July 30, 2010 at 8:03 am
    Thanks Cactus Dan! That did the trick. Many thanks to everyone else who replied too, what a great forum!
