Activity Forums Adobe After Effects Rotating a Shape Layer’s points w/o rotating the layer?
  • Rotating a Shape Layer’s points w/o rotating the layer?
    Posted by Eric Chard on March 5, 2021 at 4:01 am
    I seem to have disremembered how to rotate (or in general Transform) the points making up a Shape Layer, without rotating the Layer itself.
    I’ve also misplaced the procedure to simply lasso/rectangle select a subset of points making up a Shape Layer: I think it’s more modal than I remember and you have to be in some particular tool to accomplish this.
    So, what are the respective procedures? Tnx
    Robert Müller replied 5 years, 5 months ago 2 Members · 1 Reply
  • Robert Müller
    March 5, 2021 at 4:32 pm
    You can select and transform points when the path is selected in a shape layer or in a mask. For shape layer it has to be a Bezier path or be converted to a Bezier path. Just unfold the contents of the layer until you reach the one called “Path” (with a little stopwatch to the side)
