Activity › Forums › Adobe After Effects Expressions › Rotating a Cubic and Controling the polygon opacity
  • Rotating a Cubic and Controling the polygon opacity
    Posted by John Kevien on April 22, 2008 at 2:59 am
    I am wondering how to make it!
    A cubic rotating randomly from its center pivot,and the face(polygon) which facing to the camera become clearly(100% opacity) when it rotating toward to the camera direction. Of cause, the faces(polygons) can be seen a little(between 0 to 100%) while they can be seen by the camera.
    I hope I make my question clearly!
    And another problem. How can I make a Cubic,just using six three dimensional solid layer and then what….??
    Thanks in advanced!!
    Trent Armstrong replied 18 years, 5 months ago 2 Members · 1 Reply
  • Trent Armstrong
    April 29, 2008 at 1:34 pm
    To easily make the Cube, put a 200×200 Solid in the comp and apply these expressions:
    TO Y ROTATION:
    i = index – 1;
    i * 90
    TO ANCHOR POINT:
    w = width / 2;
    x = value[0];
    y = value[1];
    z = w;
    [x, y, z]
    *Duplicate that layer until you have the four sides of the cube. Add a camera, put it on the bottom of the layer stack, and move the camera so you can see that the layers make the cube.
    Then make two more duplicates of your Solid, remove the Y ROTATION expressions and put these two expressions in for X ROTATION respectively:
    LAYER 5:
    i = index;
    i * 270
    LAYER 6:
    i = index – 1;
    i * 90
    That’s your cube. You can change the size of your solid and it will effect the whole cube.
    As for the transparency issue …
    apply this expression to the Opacity of each of the solid layers
    delta = toCompVec([0, 0, 1])[2];
    linear(delta, 600, 1500, 10, 65)
    This whole thing obviously works best if you are using squares to build the object.
    Cheers,
    Trent
    Trent Armstrong – Creative Cow Leader
    https://www.dallasaeug.com
