Activity Forums Adobe After Effects Rotating a circle shape layer perfectly
  • Rotating a circle shape layer perfectly
    Posted by Jared Gardner on April 30, 2015 at 3:19 am
    I have a simple shape layer which is a dashed circle and I’d like to make it rotate (spin in a 2D way). I dragged the rotation keyframe thing but it’s wobbling ever so slightly. I also tried making it a 3D layer and rotating it that way but it always wobbles slightly for some reason. Is my anchor point not centered? I’m not familiar with the anchor point thing honestly.
    Jared Gardner replied 11 years, 4 months ago 2 Members · 2 Replies
  • Derek Boettcher
    April 30, 2015 at 12:24 pm
    Press y on your keyboard for the pan behind tool, click an hold the anchor point, then hold control or command which will snap the anchor point as you move it around. Snap it to the center. If it is already centered, then your circle wasn’t perfect. To get a perfect circle, hold shift while you click and drag the eclipse tool to the appropriate size.
    Best,
    Derek Boettcher
    Creative Management
    BTH Media Group
    https://bthmedia.com
  • Jared Gardner
    May 1, 2015 at 1:20 am
    It works. Thanks!
