Activity Forums Adobe After Effects Rotating a baseball on x or y axis
  • Rotating a baseball on x or y axis
    Posted by Paul Campbell on January 11, 2010 at 2:12 pm
    Finding a 2-D image of a baseball and making it roll on the z axis is easy enough, but I’m trying to make the ball spin on either the x or y axis for the true 3-D effect. I’ve used the CCSphere effect before to make 3-D planets, etc from fractal noise patterns, but the threads on a baseball (or the lines on a basketball) aren’t random, so trying to create a baseball that I can spin is proving tricky. Can someone help? Thanks.
    Craig Anderson replied 12 years, 6 months ago 5 Members · 7 Replies
  • 7 Replies
  • Henk Loorbach
    January 11, 2010 at 2:51 pm
    i think you should try to find a spherical map of a baseball on a 3d website and then use the cc spherzize filter, or try fiddling with a square photoshop file untill you find the right way to put the lines on a square
  • Michael Szalapski
    January 11, 2010 at 3:24 pm
    A quick Google search turns up what you need.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Serge Hamad
    January 11, 2010 at 5:28 pm
    Hi Paul,
    I would advise you to google for spherical mapping. Mainly your map should always have a 2:1 aspect ratio. To avoid the north & south pinch you need to use the Polar coordinates distortion effect when creating your map. Creating geometrically complex spherical maps is not an easy task, it takes time and patience;-)
    You can visit my site and check the InvigoMany-Sport for some examples.
    E-Mail me if you like the Baseball object and I will send it to you for free.
    The project was meant for Invigorator but you could also use CC-Sphere if you like. Opening the texture, transparency & bump-mapping compositions will show you exactly how these maps were created right inside of After effects.
    Salut.
    Serge
    New! InvigoMany-Media volume I & II available here:
    https://www.nyc-visual.com
    Invigorator/Proanimator Training: https://library.creativecow.net/articles/hamad_serge/invig_training.php
  • Henk Loorbach
    January 11, 2010 at 5:37 pm
    speaking of that:
    is there a good tutorial for this?
    Henk
  • Serge Hamad
    January 11, 2010 at 6:30 pm
    Hi Henk,
    The Creative Cow series “Zaxwerks-Invigorator-Training” does that in detail.
    There is also a lot of info at the Zaxwerks forum on how to create many different things. Just make a search.
    Salut.
    Serge
  • Paul Campbell
    January 11, 2010 at 8:48 pm
    Guys, thanks so much for all of the tips! This is exactly what I needed.
    Regards,
    Paul
  • Craig Anderson
    March 23, 2014 at 10:54 pm
    I am very interested in buying your invigorator project, but the web address shows under construction. Do you have a new one?
