Activity Forums Maxon Cinema 4D Rotate within an array
  • Rotate within an array
    Posted by Ryan Butterworth on April 3, 2009 at 6:00 pm
    I’m wondering if there is a simple way to do this. I set up an array and changed the scale so it’s an elipse shape. I need to rotate the objects inside without actually rotating the array. Any ideas??
    Ryan
    Adam Trachtenberg replied 17 years, 5 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    April 3, 2009 at 6:28 pm
    You can simply animate the rotation of the object inside the array, but scaling the array will cause the objects inside to distort.
