Activity Forums Maxon Cinema 4D rotate “top projection” camera
  • rotate “top projection” camera
    Posted by Olly Bea on January 26, 2010 at 8:39 pm
    Hey
    I am baffled!
    Is there a way to rotate a “top” projection camera through 90 degrees? I just want a plan view of a scene but 90 degrees anti-clockwise.
    Why am I soo stoopid? (don’t answer that)
    Olly
    Jeremy Allen replied 16 years, 7 months ago 2 Members · 1 Reply
  • Jeremy Allen
    January 27, 2010 at 4:18 pm
    This is more of a workaround. I’m not sure if you can rotate the top view, but you could add a camera, go to your top view and set the projection of the linked camera to perspective. Then rotate your camera to -90,-90,0.
    Does that give you what you need?
    8core MacPro, 3.0 GHZ, 10GB RAM, OSX 10.5.6
    C4D 11.5
    AE CS3
    FCP 6.0.1
