Activity Forums Adobe After Effects rotate text around sphere
  • rotate text around sphere
    Posted by Filip Tomic on December 21, 2014 at 1:55 pm
    Yes I know this question has been asked before but I have a different case.
    I shot a person kicking a soccer ball right at the high speed camera. I want to add text at the ball as it nears towards the camera. I tried CC Sphere but since it wraps the whole text into a sphere it’s no use (I want all the letters ‘BKZ’ to be shown at some point) . So what would be the easiest way for a beginner?
    Brian Charles replied 11 years, 8 months ago 3 Members · 2 Replies
  • Chris Brett
    December 21, 2014 at 3:53 pm
    — if cc sphere works apart from the fact that you dont want the lettering to go all thje way round then suggest you btry eithrt
    1 ) adding spaces either side OR
    2 ) adding dots either side OR
    3 ) adding vtransparent letters either side …….
    …………… good luck —-chris —-
  • Brian Charles
    December 21, 2014 at 6:19 pm
    Or make the sphere from a nested comp. Geometrically a sphere is twice as wide as it is tall so make the nested comp that proportion.
    For example:
    8319_ballprecomped.aep.zip
