rotate single Objects
Hey,
I got a problem here: I’ve created a bowl which is entirely made out of 3dimensional Triangles. I now want to select single triangles and make them rotate. But I cannot do that, I thought the problem is caused by command “fracture” and “explosion” and when I then add “plain” it’s not working. It only works when I use hexagons as objects but not with triangles/pyramid forms, so how can I do that?
Thanks a lot!
