Activity › Forums › Adobe After Effects › rotate offset
rotate offset
Posted by Susan Lan on August 19, 2015 at 3:01 pmI have this position time offset, but, how to turn into for rotation offset, please?
offset = -.5;p = thisComp.layer("My Animated Layer");
t = time + offset;
p.position.valueAtTime(t);
Susan Lan replied 11 years, 1 month ago 2 Members · 31 Replies -
Walter Soyka
August 19, 2015 at 3:26 pmoffset = -.5;
t = time + offset;
p.rotation.valueAtTime(t);Walter Soyka
@keenlive | RenderBreak [blog] | Profile [LinkedIn] -
Susan Lan
August 19, 2015 at 4:27 pmThanks Walter! I get this error, I take a capture, can you help me please?
https://i.imgur.com/YAJqgbm.jpg
9157_errorrotationoffset.jpg.zip
Walter Soyka
August 19, 2015 at 4:33 pmSince it’s referring to a 3D layer:
p.transform.zRotation.valueAtTime(t);Walter Soyka
Susan Lan
August 19, 2015 at 4:42 pmI linked the rotation of the 3d null of the ligth
to the rotation ogf the 3d null (cam control) of the cameraBoth nulls are 3D activated…
I’m not english, but I undertand “since” as “that is because”, no?
Corecct me please, Then you are saying that I must write:
offset = +.5;
p = thisComp.layer("Cam Control").transform.zRotation.valueAtTime(t);
t = time + offset;
p.rotation.valueAtTime(t);instead of:
offset = +.5;
p = thisComp.layer("Cam Control").transform.zRotation;
t = time + offset;
p.rotation.valueAtTime(t);yes? Thanks Walter!
Walter Soyka
August 19, 2015 at 9:07 pmp refers to a layer, not to the property. You’d need to change the property reference.
offset = -.5;
t = time + offset;
Susan Lan
August 20, 2015 at 6:33 amGood mornig Walter! I just try it and, I want to aks you if it is normal this: ¿it is normal that only works: if, in the line “p” that refers to the layer we only write the name of the layer to which we want to follow the rotation (instead of select that line and pick/take the whip to parent to the z rotation)??:
offset = -.5;
p = thisComp.layer("Cam Control");
t = time + offset;
instead of this in line “p” of layer (this follow get error, ¿the reason is because we tell the “transform Z Rotation in “p” property line and because of that, is not necesary tell to it again in the “layer” line?
offset = -.5;
t = time + offset;
Thanks you Walter
Susan Lan
August 20, 2015 at 1:23 pmI asked that, also because, it seems that the null of the AE-pointLigth rotates, but I can’t notice the offset, although I change -.5 to +.5
It still seems that the null of the ligth is linked to the null of the camera, both make the same rotation and position, but, I do not notice the sensation that the camera follows the light, I don’t know how to explain, I imagined to maked the ligth moving a little bit faster (time offset, no?) and that the camera follows, pursues the ligth (which in sometimes “dodge” (I don’t know the word) the camera)…🙁
Walter Soyka
August 20, 2015 at 1:34 pmI’m getting a little lost. Can you post a screenshot of your entire UI so I can see the comp layers with some keyframes and understand better what you are applying these expressions to?
Walter Soyka
Susan Lan
August 20, 2015 at 2:32 pmGood evening Walter!
Yes, thank you and sorry for the inconveniences, here I upload the image:
https://i.imgur.com/2GoYZCg.jpg
I write an expression into the: Position of the null of the ligth, to follow the position of the null of the camera (called “Cam Control”)
was this
thisComp.layer("Cam Control"); transform.position + [effect("Slider Control")("Slider"),effect("Slider Control 2")("Slider"),effect("Slider Control 3")("Slider")];then I add it, inside the code of “position offset”:
offset = +.5;
p = thisComp.layer("Cam Control"); transform.position + [effect("Slider Control")("Slider"),effect("Slider Control 2")("Slider"),effect("Slider Control 3")("Slider")];
t = time + offset;
Then I write an expression into the: Rotation of the null of the ligth, to follow the Rotation Z of the null of the camera (called “Cam Control”).
I got this to the parent-follow:
But when I want to add it, into our expression of rotation offset I must remove the part
To add, finally, like this (the expression yo tell me)
offset = +.5;
t = time + offset;
p.transform.zRotation.valueAtTime(t);P.D.: It does not looks good, because also I’m trying to turn the cone of ligth (the beam) in a manner that seems firstly that the beam are in Y axis , I mean, lookin at this frist:
https://cloud8.lbox.me/images/384×384/201203/ultrafire-decreto-xm-1000-l-t6-luz-tactica-linterna-color-camuflaje_anehzq1331188119397.jpg
and then animate the ligth beam -
Walter Soyka
August 21, 2015 at 10:38 amI’ve rewritten your expression to try to make it a little clearer what it’s doing.
Position:
timeOffset = -1;
stopFollowingAtTime = 8;referenceTime = Math.min(time + timeOffset, stopFollowingAtTime + timeOffset);
referenceLayer = thisComp.layer("LEADER");
positionOffset = [effect("offsetX")("Slider"),effect("offsetY")("Slider")];value + referenceLayer.transform.position.valueAtTime(referenceTime) + positionOffset;
Rotation:
timeOffset = -1;
referenceLayer = thisComp.layer("LEADER");value + referenceLayer.transform.zRotation.valueAtTime(referenceTime);
Please feel free to ask questions on anything above that’s unclear.
Walter Soyka
