Activity Forums Maxon Cinema 4D Rotate objects with “force field”
  • Rotate objects with “force field”
    Posted by Andy Stokes on April 7, 2006 at 6:57 am
    Hi all,
    I’d like to setup a bunch of objects (let’s 10 long thin rectangles) and have a kind of force field set to rotate the objects by 180 degrees. If I could then slide the position of the field through the bars to have them rotate as it passes across them (without deforming the objects)
    Hope this is clear. Is there a way to achieve this in cinema ?
    Cheers,
    Andy
    Chris Smith replied 20 years, 5 months ago 2 Members · 1 Reply
  • Chris Smith
    April 11, 2006 at 7:25 pm
    You could set up a TP system where it creates particles along a spline. Then have thise particles orient towards a null. Then instance a rectangle object to the particles. So when you move your null around, the rects always point at it. Somewhat like a magnetism.
    Chris Smith
    https://www.sugarfilmproduction.com
