Activity Forums Maxon Cinema 4D Rotate object movie
  • Rotate object movie
    Posted by Jim Pawlowski on October 18, 2012 at 2:48 pm
    Hello, I am attempting to take an object and output a Quicktime movie where the user would be able to manually rotate the object horizontally and vertically. When I render the movie file only has the first frame showing. Any ideas. NOTE: I am working with the registered demo version of R14 at this time, not sure if that could be the reason. I seen this tutorial online, but not in English so not sure if I am getting all the info – https://www.youtube.com/watch?v=-M-shtjXdTg.
    Render Settings
    Format – QuickTime VR Object
    Generate File – VR
    When I render to Picture viewer it acts as if it is generating 684 images, when finished I saved –
    Type
    Tried both Still Image and Selected Frames
    Format – Quicktime Move
    Options/Compression type – Animation
    Thank you for your help,
    Jim
    Jim Pawlowski replied 13 years, 11 months ago 1 Member · 0 Replies
  • 0 Replies
