Activity Forums Adobe After Effects Rotate image, not mask
  • Rotate image, not mask
    Posted by Markus Vaga on August 19, 2009 at 2:13 pm
    I’m sure this is an easy one, but for some reason I can’t wrap my head around it! (It must be too early in the morning)
    Nevertheless: I have circular brushed steel image in my comp. I want to rotate it to give the effect of a spinning disc, but want to only reveal a portion of the image. Of course when I rotate the image with the mask, the entire image rotates.
    Attempting to “correct” the mask into position as the image rotates beneath is not exact at all, and the mask moves slightly.
    Am I missing something simple? Thanks much in advance…
    Life is a Monet splendored thing…
    …so take the Monet and run!
    Jason Brown replied 17 years ago 4 Members · 6 Replies
  • Andy George
    August 19, 2009 at 3:09 pm
    Hi Markus,
    If you apply your mask to a solid above the circular image you can use
    that as a track matte to your circular image.
    Allowing independent control of both mask and object rotation.
    Fome adobe on track mattes-
    https://help.adobe.com/en_US/AfterEffects/9.0/WS3878526689cb91655866c1103906c6dea-7cf9a.html
    -Andy
  • Adolfo Rozenfeld
    August 19, 2009 at 3:23 pm
    Cut the mask, Pre-compose the layer (using the second option in the Pre-compose dialog, “Move all attributes”) then paste the mask into the resulting Pre-Comp. Rotate the layer nested inside the Pre-comp. This will let you rotate the layer without affecting the mask applied to the Pre-Comp.
    Second method: Create a new Comp-sized solid and place it immediately above your layer. Cut the mask and paste into the solid, then set the solid as a Track Matte for the layer below.
    Adolfo Rozenfeld · Adobe
  • Jason Brown
    August 19, 2009 at 3:42 pm
    Hey Adolfo,
    Just curious on your suggestion. If you had the mask on the layer and precomposed with *leave attributes in current comp* wouldn’t that accomplish the same thing?
    -Jason
  • Markus Vaga
    August 19, 2009 at 3:56 pm
    Thanks to you both for the suggestions/solutions. I knew it was relatively easy, but sometimes the mind short circuits, eh.
    I ended up using the precompose trick, although for more complex motion, track matte is the way to go, I believe.
    Thanks again!
  • Adolfo Rozenfeld
    August 19, 2009 at 4:09 pm
    Jason: that would work if there were no changes to the transform properties. If there were, scale, rotation, etc would be applied externally to the Pre-Comp, which is what you don’t want in this case, right?
  • Jason Brown
    August 19, 2009 at 5:45 pm
    Yea…good point, I’m just making sure that my understanding is correct. As my Grandpa always said, there’s more than one way to skin a cat! 🙂
    -Jason
