Activity Forums Adobe Photoshop Rotate a Brush Shortcut?
  • Rotate a Brush Shortcut?
    Posted by Ragnar on July 11, 2005 at 1:25 am
    I did an archive search and didn’t find an answer to this question. Is there a keyboard short cut for rotating a brush? That sure would come in handy instead of going to the Brushes palette and changing the angle.
    Ragnar
    Richard Harrington replied 21 years, 1 month ago 2 Members · 1 Reply
  • Richard Harrington
    July 11, 2005 at 4:09 am
    NOPE…
    You can alwats look at the Edit>Keyboard Shortcuts command to check
    You can though map brush dynamics is uding a tablet and angle can be driven by angle of pen
    Richard M. Harrington, PMP
    Author: Photoshop CS for Nonlinear Editors
    Co-Author Final Cut Pro on the Spot, After Effects on the Spot, Broadcast Graphics on the Spot, and After Effects @ Work
    Check out the new DVD: Photoshop CS: Essentials for Digital Video from http://www.photoshopforvideo.com
    edit – produce – direct –
