Activity Forums Maxon Cinema 4D Rope simulation crashing C4D when tear occurs
  • Kouraib Abdmalek
    December 23, 2024 at 9:53 am
    Hi Eric,
    It may be necessary to record the screen or share the file if possible, I don’t know the method you used to make the rope tear, whether by applying tension from both sides or by dropping something on the rope, I have attached below a tutorial on how to do this by dropping another object and then hiding it, I hope this helps you.
    https://youtu.be/DnFLOToXg0M?feature=shared
  • Eric Pereira
    March 25, 2025 at 8:49 pm
    I finally figured out why all my simulations were breaking.
    My objects were about 10 km from the origin point of my scene.
    Apparently, the simulations completely fall apart if the objects are far away from the origin.
    I now have no issues.
  • Kouraib Abdmalek
    March 26, 2025 at 7:51 am
    Oh! 10 kilometers, that’s too much! maybe the units in the project were in kilometers, anyway glad you figure out the problem, calculating simulation data for such a long distance in a limited number of time frames, so each frame might be hundreds of meters of simulation, would have definitely caused Cinema 4D crash as it happened to you, thank you very much for sharing with us, this will certainly be useful to many users.
  • Eric Pereira
    March 26, 2025 at 11:58 pm
    My project is in meters.
    I didn’t realize distance made that much difference.
    I had a scene in space where the Earth was at the centre and distance was far to make it appear correct size.
    C4D should give a warning like it does for low pyro resolution or high poly count for sims.
  • Kouraib Abdmalek
    March 27, 2025 at 7:44 am
    I don’t have exact information about this, but just a guess from previous experiences. I think that when the pressure is enormous, the program stops even before it can issue a warning. In some critical cases, the entire computer crashes until you stop and restart it. The device may even be damaged, as I saw it happen to a user who was working as part of a team on a huge stadium project that was scheduled to host an important sporting event. Therefore, I think that the matter is not a cause for concern.
