Activity Forums Apple Final Cut Pro Legacy Rookie Question : Uninstalling quicktime x and reinstalling quicktime 7
  • Rookie Question : Uninstalling quicktime x and reinstalling quicktime 7
    Posted by Mark Laslo on October 8, 2010 at 2:42 pm
    HI All,
    I have been reading a lot here that quicktime x is not something to be trusted and should be removed and that I should be using quicktime 7.
    Normally I’d just go ahead and delete the app and install the new one but I am afraid that I’ll end up corrupting the entire final cut pro suite somehow. If someone could point me in the direction of some good instructions I would be very appreciative. Also when I install 7 will it automatically register for Pro or do I need a serial key from FCP?
    Thanks for your help
    Mark
    John Pale replied 15 years, 11 months ago 2 Members · 1 Reply
  • John Pale
    October 8, 2010 at 3:40 pm
    You do NOT remove QuickTime X. You just install QuickTime 7 (actually it really only installs the QuickTime 7 Player) from your Snow Leopard Install Disk.
    FCS automatically recognizes you as a ProApp user and your QuickTime 7 player has the Pro features enabled.
    You cannot uninstall any version of QuickTime itself (it’s a lot more than just the player) from MacOSX…it’s deeply tied into the operating system.
