  • Posted by David Rickles on April 9, 2008 at 5:08 pm
    Hello all!
    I am looking to create an effect similar to a rolodex. I have looked around for stuff that might help, but i’ve been unsuccessful, and am hoping you all might be able to help an expression novice some direction.
    To put it simply, I need to flip through the “cards” pretty quickly on their x-axis, and have it pause on one specific card. I’ve tried parenting and I’ve tried an angle slider, and I”m just not getting what I’m trying to accomplish. I’m thinking there’s some conditional if/else type lines that need to go in, but don’t know where to begin with that.
    Any help would be GREATLY appreciated! Thanks!
    David
    Alexa Nel replied 11 months, 2 weeks ago 5 Members · 7 Replies
  • 7 Replies
  • Filip Vandueren
    April 11, 2008 at 4:48 pm
    Hey David,
    here’s a solution:
    OK, I created a Null with a ‘numCards’ slider and a ‘viewCard’ slider. The ‘viewCard’ is the one you’ll animate;
    Create a rolodex card-layer, put it’s anchorpoint below its lower edge
    here’s the expression for X-rotation:
    numCards=thisComp.layer("Null 1").effect("numCards")("Slider");
    viewCard=thisComp.layer("Null 1").effect("viewCard")("Slider");
    v=((index-1) * (360/numCards) + viewCard*(360/numCards))%360;
    if (v<10) {
    ease(v,0,10,-20,120);
    } else {
    linear(v,10,360,120,340);
    Let me know if it works out.
  • David Rickles
    April 11, 2008 at 10:06 pm
    That worked perfectly…is there any chance I could get you to tell me why it works? I’m still trying to learn, and that didn’t seem as complicated as I was thinking it would be….
    Thanks so much!!!
    David
    David Rickles
    Producer, Editor, Animator
    David.Rickles@gmail.com
    http://www.davidrickles.com
  • Filip Vandueren
    April 12, 2008 at 4:28 pm
    obviously creating the sliders and linking to them is to have some flexibility, otherwise if you change the number of indexcards, you have to change all the expressions…
    Next the motor of the expression:
    this basically just distributes the layer around 360°:
    using _index_ makes sure the value is different for each subsequent index-card because the calculation is based on their indexnumber,
    (360/numCards) makes sure that the angle between each card adds up to 360,
    and when viewCard gets animated, the wheel will spin.
    It ends with a %360, which wraps values above 360 back to 0: so 372%360 = 12
    if the expression were to end here, you’d simply have a wheel of indexcards evenly spaced. Animating ‘viewCard’ would just spin the wheel.
    But we want a rolodex effect: part of the spin should go really fast (the flip), and then it should go slow, untill the circle is complete.
    _v_ gives us values from 0-360, and we will interpolate them to program the ‘flip’:
    if (v<10) {
    } else {
    if v<10, we will create an ease interpolation, that yields values from -20 to +120: a very fast 140° occurs in what would be the first 10° of the cycle, using ease adds some cushioning.
    after that (v>10) the cards take their time to go full circle back to 340° (= -20°)
    ease() and linear() are two very nice methods that let you "rescale" values
  • Zach Meissner
    December 19, 2008 at 5:20 am
    thanks for this great expression! however i cant quite get it to work. on which layer do i apply the expression? i’m assuming the layer needs to be in 3d? thanks for the help!
  • Luke White
    December 9, 2009 at 3:59 pm
    This is very useful,
    Can you explain how I can use an expression on the opacity so that it eases into visibility concurrently with the movement of it slowing down.
    I tried pasting that expression into the opacity and not really sure how to adjust the easing.
    Any help?
  • David Rickles
    December 9, 2009 at 10:19 pm
    Hi Luke,
    Below is a solution I was able to come up with for this that is still driven by the same stuff that’s already being used…Apply this to the opacity layer.
    numCards=thisComp.layer(“Null 1”).effect(“numCards”)(“Slider”);
    viewCard=thisComp.layer(“Null 1”).effect(“viewCard”)(“Slider”);
    opac = v/36;
    if (opac<2) {
    ease(opac,0,2,99,100);
    } else {
    ease(opac,2,numCards, MINIMUM OPACITY VALUE,MAXIMUM OPACITY VALUE)
    To use this, change the minimum and maximum values to be what your flavor is. This will gradually make it less transparent as it approaches the "Front Cards".
    Hope that helps!
    David
    David Rickles
    Art Director | Motion Designer
  • Alexa Nel
    October 14, 2025 at 9:26 am
    KING! thankyou so much.
