Activity Forums Adobe Premiere Pro rolling title
  • rolling title
    Posted by Gary Linzer on August 5, 2008 at 2:26 am
    I’m trying to time a rolling title with narration. My problem is that the title doesn’t scroll fast enough to keep pace with the narration. If i shorten the title duration then the title ends before the narration is finished. I tried using the motion controls but the whole title didn’t show up. Only the lines that were within the frame in the source monitor. I hope my explanation makes sense. Thanks Gary
    Joe Garcia replied 18 years, 1 month ago 2 Members · 3 Replies
  • Joe Garcia
    August 6, 2008 at 1:20 am
    Hi Gary,
    Not in Premiere at the moment but let’s see what we can do,,,
    tickling the duration is not working for you so two ways to synch are to use a numbered marker, the other is to set time code manually.
    ( I know, this applies to multi cam edits,, but maybe worth a try )
    The other thing I’m thinking is,, are the title track and the narration track linked ???
    Play with these and see what happens.
    cheers
    joe
    JOE
    X-Porter
  • Gary Linzer
    August 6, 2008 at 3:40 pm
    No they are not linked. I’m not sure I understand about using a marker or setting time code manually. When I make the title does it only display what is within the viewing area of the program monitor. In other words is there a way to display my whole title without making it a rolling title? Thanks again, Gary
  • Joe Garcia
    August 7, 2008 at 10:02 pm
    1st
    the markers are generally used for synching two or more video tracks and I felt this may have been the best way to help you fix your synch problem.
    The help module in Adobe is pretty good at explaining markers but try this link where markers are use and see what you can learn about them and try to apply the technique to your needs.
    Goto this video and see markers in action..
    https://library.creativecow.net/articles/sareen_aanarav/MultiCamera.php
    2nd
    as far as how to display the title, if you de-select the ‘rolling title option’ then you can display as much as the size and length of the title will allow on the ‘source’ and/or ‘program’ windows respectively.
    However this will present a static title although you can, at this point, animate it manually with a path and some animation keyframes.
    Let me know if I properly understand. If not give us more details of what it is your trying to achieve and we’ll try to do better for ya.
    cheers
    JOE
    X-Porter
