Activity Forums Adobe After Effects Rolling text which changes color after a certain point
  • Rolling text which changes color after a certain point
    Posted by Chris Van der zaan on January 4, 2009 at 2:08 pm
    https://img176.imageshack.us/img176/6963/mono401ie6.png
    I would like to have text rolling on this bar from right to left.
    The text should start in black at the far right. As soon as a letter reaches the black part of the image it should change to white.
    I tried and thought about various ways. But every solution i think of i can’t achieve with AE. I am now just doing it the hard way and duplicating/overlaying each letter in white. But that is so much work.
    Tom Scott replied 17 years, 7 months ago 3 Members · 8 Replies
  • 8 Replies
  • Captain Mench
    January 4, 2009 at 4:11 pm
    I’d do it with two layers of text white on top of black… then apply a feathered mask keeping the shape of the diagonal line so it hides the white and exposes the black.
    But there might be another way.
    Mike
  • Chris Van der zaan
    January 4, 2009 at 5:05 pm
    Thanks. I was trying this too, but i am stuck on the mask part. When i apply a mask and draw around white part of the image it is moving along with the text. I don’t really understand what is going on.
    Do you know how i can do this step by step?
  • Tom Scott
    January 5, 2009 at 9:26 am
    Rather than animating the position of the text layers, you should use the built-in text animators.
    1: Create your text layer, with black text.
    2: Twirl down the layer and click the “Animate” button.
    3: Select “Position”, and set keyframes on the newly created “position” property of “Animator 1”.
    4: Duplicate your text layer and change the text color to white.
    5: With the white text layer selected, use the pen tool to create a mask, following the shape of the white part of your graphic.
    6: Change the masks mode to “Subtract”.
  • Tom Scott
    January 5, 2009 at 9:35 am
    Hmm, I tried to upload (and embed) an example, but apparently, “The Cow” doesn’t like animated gifs.
  • Tom Scott
    January 5, 2009 at 9:47 am
    Trying again, with a wmv file:
    No, sorry. The file doesn’t like the embedded player, so I’ll just forget about an example.
  • Tom Scott
    January 5, 2009 at 9:54 am
    Aha, flv is the ticket!!!
    January 6, 2009 at 12:04 am
    Tom. Thank you very much for your effort and help! That looks exactly like i wanted. 🙂 I am going to try this.
  • Tom Scott
    January 6, 2009 at 9:26 am
    Glad to help.
