Activity › Forums › Apple Final Cut Pro › Rolling shutter flicker
Posted by David Mayer on January 13, 2025 at 4:29 pmBest plugin to remove flicker coming from a monitor in the shot?
David Mayer replied 1 year, 8 months ago 3 Members · 6 Replies -
Devrim Akteke
January 13, 2025 at 4:53 pmWell, in my opinion, it is Digital Anarchy Flicker Free. You should try the trial version and test it before buying but I believe it will fix almost all your flicker problems.
David Mayer
January 13, 2025 at 5:00 pmThanks, Devrim. From the searching around i did, it looked like it
was between that one and Neat Video.
Devrim Akteke
January 13, 2025 at 5:06 pmNeat video is very good for noise reduction but never used it for flickering. My biggest problem with Neat Video is it is too heavy, you can’t ever playback without rendering. It is better to try both and see for yourself.
David Mayer
January 13, 2025 at 5:10 pmvery helpful – this is 3 hours of video with a flickering monitor, so heavy would not be good
Mads Nybo jørgensen
January 13, 2025 at 6:51 pmHey David,
Going back 20-years, I used ReVision DeFlicker to save a feature film that was going from HD to 35mm projection. The black levels, in a coal mine, was constant through a shot. Including, where we had to use Twixtor to slow some of the progressive footage down.
They have a FCPX plug-in version here:
https://revisionfx.com/products/deflicker/fcp/#featuresAtb
Madsrevisionfx.com
DEFlicker is your solution for problematic high frame rate and timelapse footage!
