Activity › Forums › Avid Media Composer › rolling credits
rolling credits
Posted by Rap on October 1, 2007 at 8:14 amhey guys
I have a JPEG fie that was made in photoshop of rolling credit
720*5500
how do I make this roll in AvidJon Zanone replied 18 years, 12 months ago 5 Members · 9 Replies -
Jon Zanone
October 1, 2007 at 10:32 amIf it comes in as a media file (no alpha), you could put on PIP, and keyframe the horizontal position from bottom to top or however you desire.
If it has an alpha, just keyframe the horizontal position.
Make sure to check your options on import. I forget the wording, but you want Avid to NOT resize it.
Jon
“So you want to throw out the old you – but the old you is old enough to know it won’t make it better”
Del Amitri – “Make it Better” -
Rap
October 1, 2007 at 12:05 pmsorry but I think you didn’t understand my question
my problem is not the alpha
the problem is that if I import the file it either shows the whole file in the viewer window and the font looks so small that it is impossible to read and when i make it bigger it looks very very blurry and bad quality
or the other way is that I get only part of the file, clear font , good resolution but when I move it down or up I that is impossible to roll there is nothing above the line of the frame (meaning it becomes 567 instead of 5500)what am I missing here
David Braswell
October 1, 2007 at 12:35 pmTry applying the jpeg as a Pan & Zoom. Keyframe the roll with P&Z controls.
David Braswell
October 1, 2007 at 1:46 pmRead the help file on using P&Z. After you apply, you have to point to the jpeg using the effects editor controls for P&Z.
Joe Womble
October 1, 2007 at 2:11 pmDo you have any version of Boris FX? It’s easy to import into Boris and roll the item on and off the screen.
Regards,
Joe Womble
Rap
October 1, 2007 at 6:43 pmI built it in motion but when i brought to Avid the quality wasnt perfect :'(
Jon Zanone
October 1, 2007 at 8:08 pmWhen you imported it, did you check your options? Make sure you check the ‘don’t resize’ radio button. And import it at 1:1 and see if the quality improves…
Jon
