Activity Forums Sony Cameras Rolling and strobbing like a shutter – Ex1 Problem
  • Rolling and strobbing like a shutter – Ex1 Problem
    Posted by James Gray on February 16, 2011 at 12:05 pm
    Hi All,
    I’ve got a massive problem, a client has just given me some footage which has all I can explain is a rolling stob problem. The footage was shot on an ex1 and when i shot most stuff on it I could also see the strobbing effect on this camera and it didn’t matter what shutter speed you were at.
    I hear this is a common problem with the EX1 as I’ve seen on other places but everyone has said to reshoot….
    https://vimeo.com/4291403
    But my main question is is there an FCP, AE fix for this or plugin that I can use? And is there any hardware updates that I can download to sort this out on their EX1 to save me the headache?
    Cheers
    J
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Duncan Craig replied 15 years, 2 months ago 4 Members · 3 Replies
  • Ron Pestes
    February 16, 2011 at 5:29 pm
    I think this happened when they made it slow motion. Is there a way to get the original footage or was it shot this way. The EX-1 and -3 shoot perfect slo-mo so I wonder if they processed it in some way. Check and see if this is the original footage. If it is I’m not sure if you can save it but maybe someone else has an idea.
    Apple Certified Master Pro FCS 2
    Sony EX-3
    MacBook Pro
  • Craig Seeman
    February 16, 2011 at 5:50 pm
    Without a detailed description from you all one can do is speculate why it happened but outside of certain indoor lighting conditions, I don’t have this happen.
    Reshoot is the only way to fix it but you should have a DP who knows how to spot this otherwise you’re going to experience again under the same shooting conditions.
  • Duncan Craig
    February 22, 2011 at 9:00 pm
    Strobing is generally caused when you have the shutter set to 1/50th and the country you are in has an electricity supply at 60Hz or vice versa.
    EX1
    MBP
    Short fingernails
