Activity Forums Adobe After Effects Rolling an egg
  • Rolling an egg
    Posted by Eric Olson on April 30, 2012 at 9:32 pm
    I’m trying to animate an irregular shape, ie an egg, so it looks like its rolling along the ground. Is there a way that I can pin the path of the egg shape to a particular spot while I rotate it ? I’ve already tried motion paths and auto-orient, but with no luck, the motion still looks unnatural.
    Eric
    Chris Bobotis replied 14 years, 4 months ago 4 Members · 6 Replies
  • Tudor “ted” jelescu
    April 30, 2012 at 10:01 pm
    Try Newton – great for 2d real world physics.
    https://www.motionboutique.com/en/shop
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Chris Bobotis
    May 1, 2012 at 3:11 pm
    Not sure what, exactly, you are trying to do but the Anchor position is important for this kind of animation. If an egg, you would probably want the anchor in the center and closer to bottom of the egg. Use the Pan behind tool and change the position of your anchor.
    HTH
    Cheers,
    Chris
    mettle.com
  • Benjamin Ausmith
    May 1, 2012 at 3:39 pm
    I gotta disagree with that. The anchor point needs to animate– otherwise, the egg will either overlap the surface, or won’t touch the surface, since the shape is uneven. I’m curious about how to solve this too– perhaps animating the anchor point? That is possible, right?
  • Chris Bobotis
    May 1, 2012 at 3:46 pm
    Not sure what you mean but yes you can animate the anchor position. Maybe Eric should post a link or a project file, this way we can all be on the same page. Just a thought.
    Cheers,
    Chris
    mettle.com
  • Eric Olson
    May 1, 2012 at 9:23 pm
    I solved it by auto-tracing the object, then pasting the path it created into the anchor point motion path of my object. Phew, it worked!
  • Chris Bobotis
    May 1, 2012 at 9:39 pm
    Awesome Eric. Share the link please.
    Cheers,
    Chris
    mettle.com
