Activity Forums Audio Rode VM
  • Rode VM
    Posted by Justin L. on June 2, 2010 at 10:23 pm
    Hey guys! My rode videomic finally arrived today and I was wondering, what should be the best settings to set the RodeVM on?
    Many people said that it is suggested to set the pad switch on the -10dB. Is this true?
    Is it better than 0dB?
    Justin L. replied 16 years, 2 months ago 2 Members · 6 Replies
  • Ty Ford
    June 3, 2010 at 2:58 am
    Hello Justin and welcome to the Cow Audio Forum.
    It just depends on how loud the source is and how sensitive the circuit you have it plugged into is.
    Too loud, use the pad. Not loud enough, take it out.]
    Regards,
    Ty Ford
    Want better production audio?: Ty Ford’s Audio Bootcamp Field Guide
    Watch Ty play guitar
  • Justin L.
    June 3, 2010 at 5:53 pm
    When you say take it out, does it mean set the pad to 0dB?
    Changing the Pad is really hard on the Videomic, that’s why I just want to put it in one level and not touch it again.
    And why does people say that the best pad to leave the videomic on is -10dB?
    *I manually adjust my volume on my camera.
    Thanks Ty!
  • Ty Ford
    June 3, 2010 at 6:12 pm
    [Justin Leyba] “When you say take it out, does it mean set the pad to 0dB?
    And why does people say that the best pad to leave the videomic on is -10dB? “
    Justin,
    yes removing the pad means setting to 0 reduction. Hard on the mic? What the heck are you doing to it?
    I don’t know why people say that -10 is good. maybe they all shoot in loud areas.
    Ty Ford
  • Justin L.
    June 3, 2010 at 7:36 pm
    Thank you very much Ty!
    If I’m shooting indoors should I keep the deadcat on the mic? Or remove it and just keep the foam windshield on? Does it make any difference?
    *btw, the pad switch on the rode videomic is inside the battery compartment. To change the pad, I still need to use a toothpick because the switch is really small!
    I think that’s one thing I don’t like about the Videomic.
  • Ty Ford
    June 3, 2010 at 10:30 pm
    [Justin Leyba] “If I’m shooting indoors should I keep the deadcat on the mic? Or remove it and just keep the foam windshield on? Does it make any difference?
    I think that’s one thing I don’t like about the Videomic.”
    Justin,
    if you have no objectionable wind source you don’t need the cat, inside or out. Be aware that HVAC ducts may be problematic.
    I know where the switch is.
    Regards,
    Ty Ford
  • Justin L.
    June 3, 2010 at 11:31 pm
    ok thanks very much!
