Activity Forums Field Production Rode NTG-2 with Canon 550D
  • Rode NTG-2 with Canon 550D
    Posted by Peter Hall on August 28, 2014 at 1:59 pm
    I am making a short film and, having previously used only my Canon 550D’s inbuilt mic for all audio recording, would like to up my production value and get some decent sound.
    I have been looking at the Rode NTG-2 and various Tascam audio recorders and the Zoom H4N. It seems from what I’ve heard that a decent audio recorder is essential as the pre-amps in the camera are not so great, giving a low signal/noise ratio. However some mic-recorder combinations (such as the NTG-2 with the H4N) require the gain to be turned right up before the volume is at an audible level.
    I have also been looking into field mixers…if I was to plug the Rode mic into one of these would I be able to then feed that directly to the camera? And if so, would the gain need to be turned right up?
    I have the camera, so I would need to buy at least a mic, a recorder and/or a field mixer. For a low budget production how might I get the best results?
    Sorry if this all comes across a bit ignorant, I really need some advice!
    Many thanks,
    Pete
    Andrew Rendell replied 11 years, 12 months ago 2 Members · 1 Reply
  • Andrew Rendell
    September 6, 2014 at 4:27 pm
    I’d recommend the Magic Lantern firmware for the 550D, it gives you metering and the ability to turn off the AGC, which you need to do (as well as a bunch of other things that improve the 550D as a video camera).
    I’ve had some decent results using a JuicedLink CX231 preamp and the Rode mic, but was never really happy with the way I had the headphone monitoring set up, so I’m now using a Tascam DR60D, which I think is the best/most versatile solution on a budget at the moment.
    So I reckon the Rode mic and a DR60D would be a good choice, install Magic Lantern and spend whatever cash you have left on glass 😉
