Activity Forums Apple Final Cut Pro Legacy Rock-Solid FCP System w/ Quicktime
  • Rock-Solid FCP System w/ Quicktime
    Posted by Kelley Tuck on January 4, 2011 at 3:32 pm
    Hey All,
    I have heard that the most rock solid setup for my OS (10.4.11) is to have Final Cut 6.0.3 and Quicktime 7.4.5 – I, however, cannot find download files for these, as Apple makes them unavailable after a certain period of time. When I first started out a couple years ago, I didn’t understand that everything needed to work together and updates could be potentially damaging to the stability of a system. Therefore, I didn’t save out any of these package downloads but simply let software update do its thing.
    I haven’t had any noticeable problems with the latest QT & FCP versions on 10.4.11, but this could be just me not knowing what the problems are. Any word on if this is an okay setup? If not, where can I legally find the update versions that I need (Pro Applications Update 2008-1 & QT 7.4.5)? Thanks in advance for your help.
    Current System:
    Mac OSX 10.4.11
    Final Cut Pro 6.0.6
    Quicktime 7.6.9
    Agape,
    Kelley D. Tuck
    “And so, since God in His mercy has given us this wonderful ministry, we never give up.”
    2 Corinthians 4:1 (NLT)
    Kelley Tuck replied 15 years, 8 months ago 2 Members · 4 Replies
  • David Roth weiss
    January 4, 2011 at 3:45 pm
    [Kelley Tuck] “I haven’t had any noticeable problems with the latest QT & FCP versions on 10.4.11, but this could be just me not knowing what the problems are.”
    Don’t sweat it then Kelley. If it ain’t broke, then don’t fix it. However, if I were you, I would certainly make a clone of your system drive using Carbon Copy Cloner, and have it standing by, because you already know that recreating the working system from the ground up that you have now might be harder to do as time passes.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    https://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
  • Kelley Tuck
    January 4, 2011 at 6:26 pm
    Mr. Weiss,
    Thanks for your quick reply. I do agree with your assessment – if it ain’t broke, don’t fix it. However, because I didn’t know about the compatibility issues when I first started, I have never worked with a ‘rock-solid system’ to know whether or not mine is ‘broke.’ I do experience unfortunate crashes (not often, but every once in a while), and it of course is not fun for this to happen during the export of a 45-minute movie that takes an hour to export. Should I except this as inevitable at times, or would having a ‘rock-solid system’ fix this problem?
    What other signs should I look for to know whether or not my setup is working well? As I said, I’ve come to accept and expect certain sporadic things like crashes, slow renders, bad render manager data, etc., as normal, and I have worked around them as needed. Should I keep doing what I’m doing, or are there red flags here? Thanks!
    Agape,
    Kelley D. Tuck
  • David Roth weiss
    January 4, 2011 at 6:43 pm
    [Kelley Tuck] “Should I keep doing what I’m doing, or are there red flags here?”
    Both! Crashes do raise red flags, but it doesn’t sound like you’re in serious danger.
    You should however do the following maintenance now and periodically every couple of months:
    1) Fix permissions on the system drive using Apple Disk utility
    2) Get Disk Warrior and run it on all drives
    3) Trash Preferences
    3) Clone your system drive
    If the crashes persist and become more problematic, then a clean install is a good idea. FCS 2 will still update from the Apple server and while some say that an earlier version of QT is best, I’ve had good success with the latest version when I’ve had to go back in time to cut FCP 6 projects for some clients without version 7.
    David Roth Weiss
    Los Angeles
  • Kelley Tuck
    January 4, 2011 at 8:39 pm
    Thanks for the great support!
    Agape,
    Kelley D. Tuck
